what size hose for coolant adaptor
  • tango123
    • May 2017
    • 892
    Anyone know what size of hose goes on the coolant adaptor on the block on a 3b/aby?
    Its the water feed to the turbo if im not mistaken. Its under the exhaust manifold.
    cheers
  • SteveH
    • 4460
    I can measure this later today for you. The hose is teflon lined by the look of it.
    91 Modded 3B
    14 A6 Avant Black Edition
      Tanweer, I will make you a core plug with a -6AN fitting on it
      • tango123
        • May 2017
        • 892
        Thanks for the reply steve.
        Alex that would be great. How does the old adapter come out?
        • SteveH
          • 4460
          You can pry them out, but watch you don't damage the opening for the core plug in the block. Search 'core plug removal' on Youtube.
          91 Modded 3B
