No oilpressure at start
    Originally posted by newsh
    Presume that’s what you meant to say
    Yes
    Stoopid potato fingers
    Its easy to find the oil temp sensor - it’s the only sensor on the oil pump
    • S2_avant 19930325
      • Mar 2019
      • 648
      Originally posted by Tractor Dave
      The oil temp sensor is under the car on the front right side. It has a single wire attached by a screw. If you remove that sensor, there is a spring under it and a valve. It all slides out. Make sure it's all clean and not scored and put it back the same way it came out.
      checked it no problem there , the oil pump is refurbished and checked from the former owner , checked it with him. Hehas started the car before me ,, but it has passed a while.
      • S2_avant 19930325
        • Mar 2019
        • 648
        I drained the oil , oil filter and oil cooler ,, and it smells a lot of ethanol ,perhapse thats why the pump will not pump , and you can see the etanol in the oil. But when i fill it up with new oil now , im just starting engine to get temperature and then putting the correct in it. But now to just start , what viskosity should i use ? And is there maybe a issue with oil pump that its primed with bad oil , so when i put in my start up oil it will not start any way ? Whats your opinion guys ?
        • S2_avant 19930325
          • Mar 2019
          • 648
          How much oil does the engine take with the oilfilter ?
          This gallery has 1 photos.
          • AndyP
            • 6049
            When you're cranking the engine trying to get oil pressure, take all the spark plugs out and remove the ECU fuses, this will disable the injectors and ignition and stop it diluting the oil with fuel.
            • S2_avant 19930325
              • Mar 2019
              • 648
              i did that .. this is from before
              • S2_avant 19930325
                • Mar 2019
                • 648
                still no pressure ,, so the only thing to try to get the oil pressure is to start it for 10 sek ,, put some red line assembly on the camshafts
                • steve briance
                  • Aug 2014
                  • 1455
                  If you are planning to start it for 10 seconds, turn it over on the starter for 10 seconds instead. There is a lot less load on the bearings using the starter compared to running normally.
                  It can take 10 seconds for the pump to suck...
                  Hopefully the engine was built with bearing lube throughout? It's sticky enough to stay put for a while until oil appears
                  • SteveH
                    • 4460
                    Is there no pressure on the gauge or no flow from anything you can visually see?
                    91 Modded 3B
                    14 A6 Avant Black Edition
                    • steve briance
                      • Aug 2014
                      • 1455
                      Haha, that's a good point! if the gauge isn't connected it won't ever show pressure
                      I reckon looking in on the camshafts would show oil flowing to the head and if its at the head it would be in the bearings by then.
                      • S2_avant 19930325
                        • Mar 2019
                        • 648
                        ,, i tried on the starter for 40 sek 6-8 times.
                        • S2_avant 19930325
                          • Mar 2019
                          • 648
                          Removed sensors on the left side on the engine and cranked ,, checked the camshafts ,, no oil .. nothing in the car gauge ,, nothing on ecu
                            • Dec 2017
                            • 5983
                            Have you got an oil pressure test gauge? I wouldn't keep on trying otherwise you will cause internal damage if the oil pump isn't working or something internal is blocked. Check once more using a proper pressure test gauge. If nothing, you need to strip the engine to see what the problem is.
                            • SteveH
                              • 4460
                              Oil gear drive cog on the crank? I've heard of these slipping, but can't imagine it's slipping enough to generate no oil pressure.Was it removed during the rebuild and hasn't been replaced?
                              91 Modded 3B
                              • mac2226
                                • Jun 2008
                                • 1289
                                Sump off check pickup pipe then drive gear on the crank then oil pump all best Michael
