Pulled out the old girl from the garage yesterday to give her a brief warm up on the drive.
When I switched off I noticed a thin cloud of steam coming out of the join between the top header and the core along with a tiny weep of coolant.
This is an OEM Behr radiator which I replaced a good few years back. I'm wondering if this leak could be caused by the expansion tank cap failing to release pressure in the system.
Is there any way to test the cap?
Is it possible that a radiator specialist could reseal the header/core joint? Or could be a DIY job?
Thanks for any tips.
