Hi,
Please advise. I know the timing is right before swapping the belts. If I can't be bothered cranking the engine to TDC. Is it OK if i just mark the position of the old belt with the cam and crank sprockets, remove the old belt, put the corresponding marks on the new belt and just fit the new belt over where the marks are with the sprockets? I thought this is accurate enough. What do you think?
Thanks
Thanks
