Bad idle and black smoke
  • Lopez90
    • Oct 2019
    • 119
    • Country: Norway
    Hello.
    My 3b suddenly runs rough. Havent driven it since i bought it, but it ran smooth right before this happened. I revved high once after i installed a new exhaust and the car died when the rpm went down. Since then it has run rough with alot of black smoke from the exhaust.
    Tried to plug out the MAF connector and it idle "better" actully. It runs from around 900-1000rpm on cold, and down to probalby 600rpm after awhile.
    Cleaned MAF without success. Plugged out 1 and 1 injector and i can hear it run bad when i unplug all (1 at a time). So this indicated its not a injector/spark failure? Alot of black smoke when it idles a minute.
    Thanks for any tips!
    Audi S2 Coupe
    Audi A6 C7
    VW T5
  • Tyrone Stone
    • Jun 2020
    • 10
    do you have a turbine ? and tell me more details about your car
      • Dec 2017
      • 5984
      Has a hose popped off when you revved her?
        Sounds like an air leak from a split hose.
        • Lopez90
          • Oct 2019
          • 119
          • Country: Norway
          Was a blown off hose. After driving 1,5hours to borrow a MAF, and a few hours trubleshooting it was a blown hose
          Audi S2 Coupe
          Audi A6 C7
          VW T5
            Usually is! Glad you found it
