What is it for ? the white one ? The other 2 are gor the bulky sensor ? correct ?
Cable info ?
Yes, I does matter.
white one is for start up oil pressure I believe. Cotton reel is four auxiliary gauge and above certain revs. Might be the other way around but cotton reel defo feeds aux gauges.
Fitted incorrectly it won't work properly.Nothelle S2 Avant
So i have to switch the senders ,, placement ,, and remove the sender i added to my stand alone ecu ,, and put the original sender there ? Correct ,, ? and all three original wires connecte ,, correct ? I have oil temp addede on the oil draining plug ,, any tips were i relocate my oil pressure sender ?
