RS2 exhaust cam mystery
  • Avantus
    • Sep 2007
    • 941
    • Country: Belgium
    Hi all,
    I've got a very strange RS2 cam timing problem.
    On my RS2 I always felt it lacked some low down torque, so went to dig for the source.
    The exhaust cam now appears to have the key-slot for the belt's sprocket machined one tooth wrong!
    I had problems aligning the camshaft dots, since the sprocket-mark wouldnt line up 1/2 tooth left of the camcover V.
    Started opening the cover on another RS2 so I could compare the 2, and setting the cams identically on both cars it came clear that the "problemcar" has the key machined slightly wrong...
    Measured the hub to be sure and it's a correct 9.5mm RS2 cam, head/engine ADU, ... al seems legit, so must be a production fault on the cam I guess
    Anyone ever experienced or heard this in 20vt-world??
    Cam timing itself is now OK, but my hall-sensor timing will still be off because of the 1 tooth difference in the sprocket...
    Picture is with cam-dots aligned, and turned half a tooth left to get the belt on as it should be...
    This gallery has 1 photos.
    • Dec 2017
    • 5983
    I suspect someone didn't support the sprocket when the bolt was torqued up and the key has started to shear. Mine sheared and slipped further than that. I was very lucky!
    • Avantus
      • Sep 2007
      • 941
      • Country: Belgium
      How it's machined and how it should be (and is) on another RS2.
        • Dec 2017
        • 5983
        Ah, you have removed it to inspect and the key is good. Interesting. I would ring Audi and demand a new one!
        • Avantus
          • Sep 2007
          • 941
          • Country: Belgium
          1994 warranty would be a nice one
            • Dec 2017
            • 5983
            A manufacturing fault on their flagship car costing over £40k back then. I would say its worth a go.
            • david1980
              • May 2014
              • 1025
              Worth asking, I know vw still honor front wings due to the foam on the back of the wings rusting the wings when they get wet.
