Hello guys and galls,
I drive a 93' B4 TDI Sedan, 1Z engine.
It will be two months now after the car lost power, perticulary in the lower band (below 2k rpms), its like im towing smth all the time.
I've tried running vag-com diagnostics, there are no fault codes, also no read-outs from the groups.
I've changed the pressure-relief valve on the valve head cover, washed the intercooler and checked the pressure reg. valve (N75) (its within ohm range), also checked the EGR valve controls and the EGR itself. There are no cracks or leaks in the turbo piping. The thing I noticed was that before it lost power it usually ran boost around 1 and peak at 1.2(3), now it barelly goes to 0.95.
Everything working thus far.
I'm open to suggestions.
