Annoyingly, my water pump seems to be leaking. Only after a long run and whilst cooling down. Not while driving and not when unused. I search the Forum and others have had this problem and the pump shaft was the issue. I'm not best impressed as I used a new SKF pump but bought from Autodoc. No point in taking that up with them then! I've only driven about 1500 miles since it was fitted but it was 2+ years ago.
Now, my question is, can I replace the pump without removing the timing belt? It's so long since I was in there, I really can't remember .
