Few questions about 3B engine.
  • ristokru
    • Oct 2016
    • 270
    Hello,
    few questions I Cant find answers.
    what is code for S2 3B oil cap code, powersteering v-belt code and oil filter code.
    Also i have heard that Some S2 owners use bigger oil filter than oem for better cleaning? Also one to use is Mann filter?
    Yeah Mann filters are OE equivalent. I have an ABY so not sure of the belt part numbers for yours. But this should help https://www.s2-audi.co.uk/tech_artic...rt_numbers.htm
    Service Parts
    034 115 615 A Oil Filter
    191 129 620 Air Filter
    8A0 819 439 Pollen Filter
    058VAGF5DPOR or
    101 000 016 AA
    Spark Plug
    N 043 854 1 Sump Plug Washer
    115 VAG 421 Synta Gold Oil 5 litres
    G 00 2 000 Hydraulic Oil
    Timing Belt Parts 3B
    054 109 119 G Timing Belt
    034 121 004 X Water Pump with Gasket
    N 010 143 2 Crank Bolt
    034 903 137 Alternator Belt
    035 260 849 C PAS Belt
    Timing Belt Parts ABY
    054 109 119 H Timing Belt
    054 121 004 AX Water Pump with Gasket
    034 105 229 A Crank Bolt
    078 109 244 F Idler Roller
    034 903 137 B Alternator Belt
    034 260 849 E PAS Belt
    Braking Parts
    895 698 151 Front Brake Pads
    895 615 301 D Front Brake Disc
    895 615 601 A Rear Brake Disc
    4D0 698 451 A Rear Brake Pads
    321 615 141 Guide Pin Bolt
    Ford 6141147 /
    6141148
    Rear Caliper Return Springs
    Ford 6141154 Rear Caliper Guide Pins
    Suspension Parts
    893 407 181 Wishbone Bush (Forged) 45mm
    8A0 407 181 Wishbone Bush (Cast) 35mm
    N 904 893 01 Wishbone securing bolt (combi) M10x78
    N 021 195 5 Wishbone securing locknut M10
    857 412 323 B Top Strut Mount (blue)
    8A0 412 323 D Top Strut Mount (green)
    8A0 407 465 C Front RS2 Drop Link
    895 505 389 Rear drop link
    895 407 365 A / 366 A Front Ball joints (forged)
    8A0 407 366 Ball joint (Cast) RHS
    8A0 407 365 Ball joint (Cast) LHS
    N 010 445 7 Front ball joint pinch bolt M10x45 up to chassis 8B-P-8000
    N 034 778 4 Front ball joint pinch bolt M10x50 after chassis 8B-P-8001
    N 021 195 5 Front / Rear ball joint pinch bolt locknut
    893 505 365 C/366 C Rear Ball joints
    N 010 445 7 Rear ball joint pinch bolt M10x45
    Part Number Description Notes
    857 199 415 B subframe Bush (Front of subframe) M10 up to end of 1992 Model Year
    857 199 419 B subframe Bush (Rear of subframe) M10 up to end of 1992 Model Year
    N 905 569 02 Securing bolt M10 x 75 up to end of 1992 Model Year
    823 199 347 Securing washer M10 up to end of 1992 Model Year
    8A0 199 415 B subframe Bush (Front of subframe) M12 from 1993 model year onwards
    8A0 199 419 A subframe Bush (Rear of subframe) M12 from 1993 model year onwards
    N 905 037 02 Securing bolt M12x85 from 1993 model year onwards
    N 905 808 01 Securing washer M12 from 1993 model year onwards
    Drivetrain Parts
    441 498 203 A CV Boot kit
    016 409 399 B Rear Diff oil Seal (rhs)
    Electrical
    VAS-5051/2 Diagnostic Cable
    4A9 953 503 Rear Wiper Switch
    445 955 529 A Rear Wiper Relay
    034 906 265C or
    Bosch 0 258 003 957
    Lambda Sensor
    034 919 369 C Multi Function Temperature Sender
    Cooling System
    443 121 273 E Aux Radiator Mounting Bush
    G 011 A8 CA1 G11 Coolant
    069 121 113
    Wahler 4116.87D1
    Thermostat
    N 901 368 02 Thermostat o-ring
    Engine Bay
    034 145 710 B Throttle Cut off Valve / Dump Valve
    034 198 025F Cam Cover Gaskets
    026 145 541 Power Steering Pump Plug
    443 199 381 C Engine Mount right up to chassis 8B-M-040000
    8A0 199 382 C Engine Mount right from chassis 8B-N-000001
    443 199 382 Engine Mount air con right up to chassis 8B-M-040000
    8A0 199 382 D Engine Mount air con right from chassis 8B-N-000001
    443 199 381 C Engine Mount left up to chassis 8B-M-040000
    8A0 199 381 Engine Mount left from chassis 8B-N-000001
    443 199 382 Engine Mount left air con up to chassis 8B-M-040000
    8A0 199 382 Engine Mount left air con from chassis 8B-N-000001
    Other
    893 253 147 D Exhaust Hanger (rear)
    895 601 165 Alloy Wheel Centre Cap (Avus)
    443 927 817 / WABCO 899 760 510 4 ABS Sensor Clamping Sleeve
