Depinning connectors and buying new PINS
  • S2_avant 19930325
    • Mar 2019
    • 648
    H , is it possible to buy new pins like in the picture ? How do you depin that black connector on the picture ? What depinning tool ?
    Best Regards
  • SteveH
    • 4460
    Contact Alex - Error404. I'm sure he can help you.
    91 Modded 3B
    14 A6 Avant Black Edition
      Terminals for those round connectors are obsolete from AMP/Tyco unfortunately.
      • S2_avant 19930325
        • Mar 2019
        • 648
        Hmmm .. to bad will solve it another way , do you know what tool to use to dissamsemble the black connector on picture 2 ?
          Normally I think, when there’s a pink piece, it means that it’s separate and can be removed to release the pins
            The pink locking insert comes forward to release the terminals from the rear
            • S2_avant 19930325
              • Mar 2019
              • 648
              Aha ,,, great but i tried a little bit .. but how do you get it to go forward ?
              • S2_avant 19930325
                • Mar 2019
                • 648
                IS there any spec on how to red the different color cods on a wiring sheet ?
                For example
                nr/ro
                gn/ge
                sw/bl
                  • Dec 2017
                  • 5991
                  To remove the pins you need to use the small pin tool (or a paper clip). It takes practice.
                  Your wiring diagram should have a code. From my Haynes manual it's as follows,
                  ge yellow
                  ws white
                  ro red
                  li lilac
                  bl blue
                  gr grey
                  gn green
                  br Brown
                  sw black
                  • S2_avant 19930325
                    • Mar 2019
                    • 648
                    Great , so i assume that is the colors used , there is not more colors the those you wrote ? Can not find in my wiring diagram the color codes.
                      • Dec 2017
                      • 5991
                      Yes but no nr or ge in my code. I can't help further. Probably a German abbreviation.
                        For example
                        nr/ro
                        gn/ge
                        sw/bl
                        It’s German, sw/bl is swartz/blau (black/blue)
                        gn is grune (green) and he is gelb (yellow)
                            Oops Dave already got there
                            Don’t know what nr would be though.
                              As above, letters are colours, abbreviated from German. Numbers is the wire CSA (cross sectional area) in mm2
