Hi guys
The cableharness that goes to the ABS unit has been cut , i think its to the ABS unit , does it go to a connector of some sort ? And is hthe connectors still around ? I want to mount get the ABS back again.
Se picture.
The harness that comes from the firewall , the upper hole , the 2 fat red cables has been extended , original its one brown and on red fat cables.
What is the connector with 3 holes ?
What is that connector for thats below the 3 hole connector ? Its plastic.
Best regards
Se picture.
Best regards
