Hi, how do I best replace the seals at the water collector pipe at the cylinder head connections (ABY). What do I need to disassemble? Is it possible to do it from the front by removing only the steering pump....or do I need to remove the intake collector? Is there anywhere a guideline to do the work? Thanks
ABY Replace seals of water collector at cylinder head
I did mine but left the IM in place, with the radiator out it wasn't a bad job.
The "shaped" seal wasn't available from Audi but it's also used on VW Golf apparently so was available aftermarket..... JP GROUP 16V Cylinderhead Coolant Flange Seal - 1119606200 5710412050078 | eBay
Just disconnect the cables to the sensors, water hose from the radiator and turbo pipe.
I have genuine Viton seals in stock:
https://www.ultraperformance.co.uk/s...keywords=VitonPanthero Coupé quattro 20vt
