Which piston set
  • taycoss
    • Aug 2011
    • 25
    Which piston set
    Anyone recommend or have tried and tested a piston set for an aan engine. Dont want to run lower compression and have been looking at wiseco, je and fcp. Already have fcp rods.
    thanks
  • SteveH
    • 4460
    FCP or Wiseco would be preferable over JE due to the alloy JE use and its expansion rate.
    91 Modded 3B
    14 A6 Avant Black Edition
    • andyg plym
      • Nov 2006
      • 4646
      I’ve had some wossner pistons installed got them from USA as seem to be cheaper
      • LSG
        • May 2010
        • 897
        We use Wossner in a lot off the busa's , Gsxr 1000,s, ZX12R,s, ZZR 1400 and Blackbird's motors . We don't have problems with them to be honest. I think you should be fine with them.
        • AndyP
          • 6049
          My experience with FCP pistons is that they are made by JE and re-branded, so just check if your getting 2618 or 4032 alloy.
          • Stealthacq
            • Nov 2015
            • 137
            4032 all the way
            • SteveH
              • 4460
              I thought they used rebranded Wossner, didn't realise they used JE. They didn't seem to have much in stock the last time I checked.
              91 Modded 3B
              • taycoss
                • Aug 2011
                • 25
                Think i will prob go for fcp ones as slightly higher compression than wossner. Car will be running on race fuel all time.
                • mllen89
                  • Apr 2015
                  • 63
                  Mahle
                  • ejfluhr
                    • Sep 2015
                    • 33
                    I just ordered 2 sets of pistons from Jeff @ Four Ring Performance because his design is ~9.1:1 compression ratio.
                    Your one-stop-shop for high performance and racing engine design and construction.
                    Seems to be made by Wiseco based on his specs. I went with 81.5mm to rebuild my street AAN and a set of 83mm for the 7A-based race car. He indicated that these will clear the standard MLS head gasket, as using that was an important factor for me (for future rebuilds of the race motor).
                    • YELL MAN
                      • Dec 2005
                      • 535
                      • Country: Shetland Islands
                      Sorry to hijack your tread but my car is needing a rebore and the machine shop can't seem to source standard type oversize pistons.
                      I am thinking the best solution is to just fire some FCP pistons in and maybe X-Beam rods while i'm at it just to futureproof it although right now the engine is standard other than a homefry.
                      I'm in the UK so where would be the best place for ordering a set? FCP-Engineering.com or is there anywhere closer that anyone has had dealings with?
                      1994 Indigo Blue S2 coupe
                      1994 80 Avant 1.9 TDI
                      2005 Yamaha Fazer 1000
                      1953 AJS Model 18S
                      • taycoss
                        • Aug 2011
                        • 25
                        QUOTE=YELL MAN;n2098079]Sorry to hijack your tread but my car is needing a rebore and the machine shop can't seem to source standard type oversize pistons.
                        I'm in the UK so where would be the best place for ordering a set? FCP-Engineering.com or is there anywhere closer that anyone has had dealings with?[/QUOTE]
                        I have used fcp a couple times now and no issues with fast shipping. Least can get parts needed all from same place. Mines also getting rebore and 82mm pistons
                        • YELL MAN
                          • Dec 2005
                          • 535
                          OK, thanks for the reply. Will probably go for ordering through them then. Need to check with machinest but looking to go for 81.5mm.
                          1953 AJS Model 18S
                          • Settari
                            • Jan 2011
                            • 69
                            Hello,
                            Need some help with choose new pistons my S2 3B engine. It's a street car, but sometime 1/4 mile or track days. I have already good rods with 22mm top end, so need to order custom pistons.
                            Which compression ratio you would recommend?
                            I have thought that close to the original 9.3:1 could be good. However, I have heard that it is actually lower than what is reported?
                            My engine horsepower target is 900hp.
                            Other specs is: fuel e85, fully ported head, Presicion 6466 gen2 0.82ar, 7a cams. Mayby need boost 2.5bar+
