My car and its mods.
The car is located on the east coast of South Africa at sea level.
Its an S2 ABY Coupe
The mods are: 440cc injectors, R8 coils, RS2 turbocharger, "RS2" Exhaust manifold from a group buy, 3" DP and exhaust system, RS2 intercooler and the ECU was sent to Prj to be mapped, according to the info on the ECU its his Stage three software.
Firstly has anybody any experience with these types of fuels.
The issue I have with my car is at high revs it appears to be holding back/pulling back at high rpm. About 5500rpm upward in 3rd gear and about 5000rpm in 4th 5th and 6th gears.
This pulling back is less noticeable on a cold day or if I add an octane booster.
I was at a tuner 2 days ago who said it is the South African low octane petrol that is most likely the issue and that its more than likely the boost etc will needs to be reduced. He also said do not change the software just try Avgas first and see how the car runs. I have no experience with Avgas and I am also concerned that messing with the present software may not be a good idea.
I have located a local airfield that will sell me some Avgas all be it 25% more expensive than pump fuel. If it works and its safe my intension would be to find a mix ratio that eliminates the pulling back and if I had to I would use just 100% pure Avgas.
What do you guys recommend? is it safe short and long term should I give it a try or is there an alternative I should be looking into.
ORSUM aka Steve
Its an S2 ABY Coupe
Avgas 100/130 | Small piston engine aircraft. | A leaded fuel. |
Avgas 100LL | Small piston engine aircraft. | A low-lead version of Avgas 100. |
ORSUM aka Steve
