Hi guys
Found a broken plastic part on the backside of the engine.
OEM nr:034121143E is on the part.
The right way to go is a aluminium one like this?
https://www.ebay.com/itm/Wasseransch...4AAOSwiAdgR4kq
Or do you recommend something else ?
Not the cheapest part but saves problems.
Feels like the plastic can break again if i try to buy something original ?
Is it a common problem ?
The correct dimension on the original oring is 21x3 .. correct ?
Best regards
Best regards
That's good to know, I got one from you many years ago but you never know when another 20v might come along.
