Head Removal and rebuild advice thread...
  • Fat Audi 80
    • 10547
    Afternoon all, I am about to "pull" the head off my S2 and would like to start a thread in which I can ask questions and you knowledgable folk can point me in the right direction!
    My aim over the next week or so, is to get the cams out of the head and remove it before taking it in for skimming, now valve guides and valve stem seals at https://fiennesperformance.co.uk/ formally Rob Walker Engineering.
    Current status:
    Turbo is off and at Turbo Dynamics for a rebuild
    IM is off
    Water Manifold is off
    I am about to remove the slam panel, remove the Aux rad and then set the Engine to TDC.
    At that point, I intent to undo all the Cam caps to remove the cams (I think this will be easier in situ as I don't have a bench to work on )
    • Do I need to take the cam caps off in any order and I assume I need to mark them / keep ordered so that they all go back in the correct locations?
    • Can I just leave the cam sprocket on the ex cam?
    • When undoing the cylinder head bolts is there a loosening sequence or detorquing process?
    • Should I renew the Cam Chain? On examinaion, I can't "feel" any play at all and it feels really nice and taught. (Car is on 190,000)
    Any think you think I may have missed or should know. What else can be done while I am in there?
    Thanks,
    Steve
    The Perfectionist
    • Dec 2017
    • 5984
    You need to do some homework!
      • Dec 2017
      • 5984
        • Dec 2017
        • 5984
        This is from the Haynes manual for the Audi 80. It covers the 20v engine which is very similar.
        I suggest you buy a second hand manual.
        A good torque wrench is also essential.
        Take pics of everything in detail at every stage so you have something to reference back to.
        The last one I did, I used a large rectangular box and drew all the parts and numbers on it so I could lay things out in order.
          • Dec 2017
          • 5984
          Yes, change the chain for sure.
          Unless yours is high mileage, I wouldn’t change the valve guides unless they are worn. Use good quality valve stem seals and gasket set.
          • Fat Audi 80
            • 10547
            I Have that Haynes Manual!! I had not even thought to look in it for the S2 engine!
            Thanks!
            The Perfectionist
            • Mikes2
              • 1704
              Before removing the head, undo the crank bolt since you'll be fitting a new belt. The cam caps are specific to the head. Do not mix them up. Workshop manuals are available from my site if you need them. Undo the head bolts in reverse order to the tightening sequence.
              Mike
              http://www.s2-audi.co.uk
              • Fat Audi 80
                • 10547
                Thanks Mike... ​​​​​​
                The Perfectionist
                • sjw185
                  • 1175
                  I bought a plastic box to keep everything sorted may help if your struggling for space 4ED37E27-52C9-4F60-9ADA-8030051D9172.png
                  • Fat Audi 80
                    • 10547
                    That's not struggling for space!
                    This is: IMG_20210427_142933 med.jpgGood advice re: boxes though!
                    The Perfectionist
                    • Bowie69
                      • Nov 2013
                      • 2675
                      Hey, at least you have a space to put the car in to work on....
                      • Fat Audi 80
                        • 10547
                        True!
                        The Perfectionist
                        • Fat Audi 80
                          • 10547
                          Can someone confirm, do I need to bag and number each hydraulic bucket tappet for each valve? It seems to suggest so in the Workshop manual? Ta
                          The Perfectionist
                          • John.
                            • 2615
                            I would, I'd be wanting to put all the valvetrain bits back where they were prior to removal.
                            • Bowie69
                              • Nov 2013
                              • 2675
                              Agreed, no brainer really.
