Idle valve info
  • S2_avant 19930325
    • Mar 2019
    • 648
    Idle valve info
    Hi , these 3 models of valve.
    0280140545 ,,,,,, 0280140525 and the one on the picture ,, what kind are they ?
    Idle solenoid PWM or idle solenoid PWM inverted or stepper ? idle valve e28 m535.jpg
  • steve briance
    • Aug 2014
    • 1455
    Bimetallic strip sliding a valve plate.
    • S2_avant 19930325
      • Mar 2019
      • 648
      I know that part , what are the idle valves called by name ?
      Idle solenoid PWM or idle solenoid PWM inverted or stepper ??
      • steve briance
        • Aug 2014
        • 1455
        You asked what type they were!
        I'd imagine they may well be called a whole load of names - cold air valve, cold idle boost ETC. If it matters to call it the right name, research some diagrams for bosch K jetronic injection and see what bosch call it.
        • Nuvo
          • Nov 2003
          • 3825
          Bosch literature refers to it as an auxilliary-air valve or device.
            They are neither, more a warm-up valve than an idle control valve, as there is no "control".
            • johne
              • Apr 2007
              • 1405
              [QUOTE what kind are they ?
              Idle solenoid PWM or idle solenoid PWM inverted or stepper ?[/QUOTE]
              They are none of these, they're not for idle, they're not PWM, they're not stepper, they are good old fashioned analogue. As Alex says they are for warm up and during that time they supply extra air which also will cause extra fuel since the fuel flow flapper will be opened more by the extra air flow.
              • steve briance
                • Aug 2014
                • 1455
                It appears its only the correct name sought
                • johne
                  • Apr 2007
                  • 1405
                  Ah, sorry misunderstood. Auxiliary air regulator or sometimes Auxiliary air valve.
                  • Bowie69
                    • Nov 2013
                    • 2675
                    Always known as 'extra air valve' in the land rover world on flapper efi.
                    • SSPRL
                      • Aug 2020
                      • 18
                      • Country: Ukraine
                      PWM
                      2 pin - 1 coil 3 pin - 2 coils
                      • S2_avant 19930325
                        • Mar 2019
                        • 648
                        Great info ,, so i have to change my idle valve.
                        Have that on my picture above
                        I have these 2 ... the left one -0280140524 ..... the right one .. 0280140545.
                        They are both 3pins.
                        How do i check them if they work before i install and how is the wiring on the pins ?
                        I supose that you mean that these more of a idle solenoid ?
                        What brand and what do people buy when building a new engine ?
                        Its a e28 m535 with turbo.
                        Best Regards
                        • Bowie69
                          • Nov 2013
                          • 2675
                          Those are idle control valves, PWM driven, three pin has two coils, and potentially more stable than the two pin versions.
                          They are horrendously expensive to buy new, so doubt any does that, and just rely on second hand stuff.
                          • S2_avant 19930325
                            • Mar 2019
                            • 648
                            Hmm .. how about the wiring ? what pin to what ?
                            • SSPRL
                              • Aug 2020
                              • 18
                              • Country: Ukraine
                              it depends on your ECU. some support 3 wire pwm, some require non-standard solutions
