I plan to build forged 2.5 stroker engine that shoud be able to ''hold'' up to 1000hp. The plan was to use 2.5 tdi block but I heard that there was a problem with some of tdi blocks that were cracking on 5th cylinder letting water in and braking everything due to hydro lock. This usually happens over 800hp. Do you guys have any info or experience regarding this issue and do you know which tdi blocks are the ones that could hold over 800hp?
2.5 TDI block for over 800hp
I got my 2.5tdi block from Andy partridge s2 forum member he’s in the U.K. Never heard this problem before but if you want a short block then he’s your man to speak to. All best MichaelI plan to build forged 2.5 stroker engine that shoud be able to ''hold'' up to 1000hp. The plan was to use 2.5 tdi block but I heard that there was a problem with some of tdi blocks that were cracking on 5th cylinder letting water in and braking everything due to hydro lock. This usually happens over 800hp. Do you guys have any info or experience regarding this issue and do you know which tdi blocks are the ones that could hold over 800hp?
I've supplied quite a few of these, all AAT or AEL blocks and I've never heard of cylinder 5 cracking. The only one I know of that holed a cylinder was when someone tried using a non-turbo 2.4D block from a T4 van, AAB engine I think.sigpic
1976 RD250E / 350LC cafe racerComment
