Crankshaft pulley bolt - p/n 034 105 229a not available
  • gvr
    • Dec 2007
    • 43
    • Country: South Africa
    Dear All,
    I have a RS2 ADU Motor and Audi Dealers say it is NLA, anyone know what size bolt and what strength steel it is made of?
    Regards
    George
    • Dec 2017
    • 5992
    Still available from Tradition
    • Mikes2
      • 1704
      It's M18x1.5, 65mm long but unless it's damaged it can be re-used
      Mike
      http://www.s2-audi.co.uk
      • gvr
        • Dec 2007
        • 43
        Hi Mike,
        Is this a stretch bolt?
        Regards
        George
        • John.
          • 2615
          If it can be re-used it won't be a stretch bolt.
            • Dec 2017
            • 5992
            It's a tough one. 12.9 grade. Avoid the febi copy as it has a much thinner collar.
              Should the bolt be used with a washer / diamond washer ?
                • Dec 2017
                • 5992
                Yes. Still available from ebay.​​​​de if your old one is damaged.
                • Mikes2
                  • 1704
                  Originally posted by gvr
                  Hi Mike,
                  Regards
                  George
                  As John has hinted at, it's not a stretch bolt. Tightened to 450 Nm
                  Mike
                  • s2driveruk
                    • 12696
                    Could be worth getting some custom ones made to the correct dimensions. Any interest?
                    1992 3b S2 Coupe
                    • gvr
                      • Dec 2007
                      • 43
                      I agree, I will be interested should their be other members who agree.
                      • larsaskogstad
                        • May 2020
                        • 674
                        • Country: Norway
                        The same for the SWAG one? I was checking for 3b s2, Febi and Swag both popped up in the webshops.
                        https://www.s2forum.com/forum/member...-3b-1991-coupe
                          • Dec 2017
                          • 5992
                          Not seen the swag one.
