Turbo oil return pipe to block torque setting
    • Dec 2017
    • 5984
    Just changing the gasket as I had a small oil leak from the turbo oil return to block pipe. Did a search here and found 10nm for the bolts. These are M8 so that seems very low
    An internet search suggests 18ft lb (24nm) which sounds more like it. Anyone have the Bentley manual and can check for me please?
  • SteveH
    • 4460
    I use a little RTV on both sides of the gasket and snug it up. I'd guess at 20Nm.You can't really go wrong as the bolts are M8 and the flange on the return pipe is thick.
    91 Modded 3B
    14 A6 Avant Black Edition
    • SteveH
      • 4460
      Just checked the workshop manual and its 22Nm
      91 Modded 3B
        • Dec 2017
        • 5984
        Excellent.
        I did the same with the rvt.
        • Mikes2
          • 1704
          My manual is saying 25 Nm
          Mike
          http://www.s2-audi.co.uk
          • SteveH
            • 4460
            I bet anything over 20Nm will crush the gasket. If it leaks tighten it a little. I use the Audi 200 workshop manual which is correct for my 3B. The ABY might have been revised.
            91 Modded 3B
            • Mikes2
              • 1704
              That's for the AAN / ABY
              Mike
                • Dec 2017
                • 5984
                I've done it to 22nm and with the rvt I'm sure it's good.
                Thanks everyone for input
