Should there be a bolt through the 3b cam idler pulley
  • 220bhp
    • 2578
    • Home: United Kingdom
    Just changed the water pump on my 3b s2 and noticed there is no bolt through the centre of the cam idler pulley ,should there be one
  • Mikes2
    • 1704
    yes, there should be. Surprised you've not got an oil leak as it goes into an oil way
    Mike
    http://www.s2-audi.co.uk
    • 220bhp
      • 2578
      Thanks for that . This is quite worrying as the guy doing the work said he did not take one out . So it’s ether been running without one or it has snap of in some way . What size is this bolt and does it have a part number.
      • Mikes2
        • 1704
        It's M6x62, N010 368 1. Just reading your first post. We are talking about the pulley in the oil pump ?
        Mike
        • 220bhp
          • 2578
          I will get a picture up tomorrow
          • 220bhp
            • 2578
            These pics where taken this morning showing the idler pulley in question . The bolt is missing and, I have since found out that it is 6mm bolt that fits through the 8mm hole . Is the pulley pressed onto the oil pump . As mentioned above the bolt go’s into an oil way . Is the bolt there to simply hold the pulley in place or is it to help clamp the oil pump .
            This gallery has 2 photos.
            • Mikes2
              • 1704
              yes there should be a bolt - M6 as above. The pulley is a press fit into the oil pump. The bolt is just a locator for the pulley but it also fills the oil way
              Mike
              • 220bhp
                • 2578
                Thanks you so much
