RS2 Engine knock developing!!
  • topsparky
    • Oct 2005
    • 2014
    j3sus i thought i had problems today with mine
    good luck in finding the fault/problem
    if you want a hand i'm not that far away so just give me a sound
    i might not be very bright but i can lift heavy fings
    1. SHORT SHIFT KIT
    2. PORSCHE CAYENNE CALIPERS
    3. H & R SPRINGS
    4. BILSTEIN SHOXS
    5. NEW BUSHES AND HP2 STRUTS
    6. UPRATED HIGH OUTPUT COIL PACK
    7. ,3" turbo back s/s/ exhaust
    8. fmic fitted
    • GT500
      • Jun 2006
      • 2181
      Yes I wasn't too happy about having to do this! but now it s out and i can get it on the engine stand and sort it in comfort! I hate Lying under cars, oil dripping in your face, having taken the sump off!
      Thanks for the offer of help! I'll see how i go, I think it will be an hour here and there... I really don't have time for this!
      Cheers,
      Rob..
      87 UR 20v ABY
      97 S6 Avant
      • s2dude
        • Nov 2005
        • 1631
        Nice work Rob
        Hope the stripdown/re assembly is trouble free.
        • GT500
          • Jun 2006
          • 2181
          YYYYYYEEEEEEEEEEEEEE HHAAAAAAAAAAA!!
          Just stripped the ****** and found the knock!!!!
          would you beleive it? the oil pump!
          The dogs for the drive off the crank are well worn, in the pump that is, crank perfect.lots of back lash = knocking noise!
          Going to fit some total seal rings as the pistons are well mucky with blow by.
          So who stocks the rings?
          all the bearings are like new!!
          tonight!
          Rob..
          87 UR 20v ABY
          97 S6 Avant
          • BRY
            • 3755
            #20
            Lucky, Lucky *******
            • GT500
              • Jun 2006
              • 2181
              £250.89 for an oil pump!!!!! stealers is the name!
              Rob..
              87 UR 20v ABY
              97 S6 Avant
              • topsparky
                • Oct 2005
                • 2014
                F M sounds like the manager wants a holiday
                and he wants you to pay for it
                1. SHORT SHIFT KIT
                3. H & R SPRINGS
                4. BILSTEIN SHOXS
                8. fmic fitted
                • Mark Halligan
                  • 2001
                  WELCOME TO PERFORMANCE UNLIMITED Distributors for some of the most respected racing engine component manufacturers PISTONS - BLOCKS - CAMSHAFTS - CONNECTING RODS - CONVERTERS - CYLINDER HEADS - DAMPERS - GASKETS - OIL AND FUEL FILTERS - DRY SUMP SYSTEMS - OIL PANS - ROCKER ARMS Contact us Pistons Including Custom Pistons Connecting Rods
                  Mark - Modded
                  • GT500
                    • Jun 2006
                    • 2181
                    Cheers Mark,
                    And its just up the road!
                    Rob..
                    87 UR 20v ABY
                    97 S6 Avant
                    • GT500
                      • Jun 2006
                      • 2181
                      update
                      I have nearly all the parts, and spent god knows how many hours cleaning, honing ect..
                      Thought i'd pass on some things,
                      best way to clean stuff? in the dish washer! our lass don't mind!
                      How clean?
                      Rob..
                      87 UR 20v ABY
                      97 S6 Avant
                      • GT500
                        • Jun 2006
                        • 2181
                        And thanks to Ben (S2 Avant)
                        Torque specs for RS2, I couldn't find them on here.
                        Mains 65Nm
                        Big Ends 30 Nm + further 1/4 (90°) turn
                        Flywheel 40 Nm + further 180° (1/2) turn
                        Clutch 25 Nm - Loosen and tighten bolts in stages and diagonally
                        Headbolts:
                        ‒ 1st stage: 40 Nm
                        ‒ 2nd stage: 60 Nm
                        Then, Using a fixed wrench to tighten:
                        ‒ 3rd stage: 90°(1/4) further turn
                        ‒ 4th stage: 90°(1/4) further turn
                        Rob..
                        87 UR 20v ABY
                        97 S6 Avant
                        • rs2315
                          • Jun 2006
                          • 867
                          [ATTACH]12504[/ATTACH]
                          How clean?
                          Rob if I ever get an invite for tea I'll bring my own plate if that's o.k. with you.
                          rs2315.
                            #28
                            Good result Rob... Must admit I would have been utterly gobsmacked if it was crank related. Pretty rare that its the oil pump actually - but thats a result.
                            Does remind me that I need to put crucial torque settings like that onto s2central one of these short short days.
                            Bet you are relieved now - have a beer of three !
                            • europeanme
                              • Oct 2005
                              • 3817
                              Glad to hear it wasn't anything major!!!.......
                              Good luck with the rebuild.....bet you have some bits left over :mischeif:
                              • Dan_s2_coupe
                                • Aug 2006
                                • 482
                                this is the came as i have a slight knock as u start 2 raise the revs slightly
                                How exactly did u see the damage and could it be done with the engine in
