RS2 Engine knock developing!!
  • GT500
    • Jun 2006
    • 2181
    Yes sounds similar,
    PM me your mail as i took a video and you can hear my knock quite clearly.
    Oil pump is in car change, sump off, pick up off, and crank pulley.
    Rob..
    87 UR 20v ABY
    97 S6 Avant
    • Dan_s2_coupe
      • Aug 2006
      • 482
      After listening 2 ur video mate sounds different its there at idle ans raises with the engine it is near the front of the engine sounds almost pas pump but cant be must be lower wot kind of tensioners does the ABY have does ne 1 have ne pictures of them?
      could possibly be bottom pulley not sure
      • GT500
        • Jun 2006
        • 2181
        Try running it with a belt off at a time. rules out the alt/ps pump/air con.
        Slack timing chain between cams?
        tensioner would be a growl (******d bearing) it only has one.
        Rob..
        87 UR 20v ABY
        97 S6 Avant
        • Dan_s2_coupe
          • Aug 2006
          • 482
          Wot could u do if there was a slack chain then
          It sounds like a knock back and forwards like a ribbed belt tensioner
          i tryed taking a video but cant transfer it from my camara for some reason
          • GT500
            • Jun 2006
            • 2181
            If chain is knobbed, just get a new one, £35 at the stealers,
            See if you can send me your vid, I'll have a listen!
            Rob..
            87 UR 20v ABY
            97 S6 Avant
            • Dan_s2_coupe
              • Aug 2006
              • 482
              is there a chain tensioner
              • GT500
                • Jun 2006
                • 2181
                No.
                Rob..
                87 UR 20v ABY
                97 S6 Avant
                • GT500
                  • Jun 2006
                  • 2181
                  Update!
                  After more fook ups with piston rings than you can beleive its back in and running!
                  Wish I had listend to Mark and orderd my Total seal rings from Performance Unlimited.
                  Instead I gave the order to a so called friend and business college. Redline Racing Developments, Brighouse. how can it take four weeks to get some rings?
                  Well I have heard them all with this git. "stuck at customs"," ups at fault". then they turn up, great ! no, wrong size 2nd ring. My "friend" says its total seals fault for sending the wrong rings.
                  turns out all balls, my "friend" did not order the rings for three weeks! tossa!
                  I rang a few times, " i don't want to hassle you but I need to get them asap!" and hadn't even orderd them!! sausage head!
                  I have found all this out having contacted Total seal to give them the biggest bollarking, only having to save the bollarking for my "friend"!!
                  I am still in shock at the Olympic gold perfomace at liying!
                  I am sure he gets off on letting folk down.
                  Anyway rant over, and I did walk away before my temper got the better of me! must be getting old!
                  RS is running as of tonight, all sounds good, no leaks, and no knocking noise!!!
                  Running in next, ooh fun,,,,,
                  Rob..
                  87 UR 20v ABY
                  97 S6 Avant
                  • 220bhp
                    • 2578
                    • Home: United Kingdom
                    #39
                    Well done mate,job done,can't wait to get mine going still a way to go though,make sure you put a drawing pin in your right shoe while your running it in
                    • GT500
                      • Jun 2006
                      • 2181
                      Good idea with the pin!:mischeif:
                      100 miles and alls well!
                      Couple of pics:
                      Rob..
                      87 UR 20v ABY
                      97 S6 Avant
                      • GT500
                        • Jun 2006
                        • 2181
                        And I am so liking my new cup lip spoiler!
                        My dog likes it! it scoops up all the road kill!
                        Rob..
                        87 UR 20v ABY
                        97 S6 Avant
                        • Jon441cc
                          • Dec 2005
                          • 2061
                          Have you thought about fitting a couple of little splitters infront of the rear tyres.
                          [IMG][/IMG]
                          • topsparky
                            • Oct 2005
                            • 2014
                            glad you've sorted it mate
                            i like the spoiler
                            1. SHORT SHIFT KIT
                            2. PORSCHE CAYENNE CALIPERS
                            3. H & R SPRINGS
                            4. BILSTEIN SHOXS
                            5. NEW BUSHES AND HP2 STRUTS
                            6. UPRATED HIGH OUTPUT COIL PACK
                            7. ,3" turbo back s/s/ exhaust
                            8. fmic fitted
                            • s2dude
                              • Nov 2005
                              • 1631
                              Nice work Rob
                              Your car is quite frankly looking....gorgeous in that Noggy Blue
                              and now the engine bay will be a detailers dream going on how clean the engine is now!
