RS2 - Oil Warning Light at Idle - 1.0 bar
    • Dec 2017
    • 5984
    • Bowie69
      • Nov 2013
      • 2675
      Or even a slim adjustable should be able to get in there, once loosened it will unscrew very easily.
      • K Simmonds
        • Dec 2007
        • 7627
        I've always used a stubby open end spanner, they're not tight as a rule so as soon as you've uncracked it you'll find it should be hand tight.
        Sent from my SM-A115F using Tapatalk
        1990 B3 2.0 80 quattro.
        1992 C4 2.8 Avant quattro
        1994 MTM RS2.
        1998 B5 TDI quattro Sport.
        2000 B5 TQS.
        • Bimmerod
          • Nov 2019
          • 29
          Is that a 19mm or 21mm open ended spanner?
          I don't have the new one in my hand yet to check. I want to locate a couple of wrench options before this weekend.
          • Rikki Kitto
            • Feb 2010
            • 6276
            When I swapped to the bigger oil filter I got better hot idle oil pressure went from 1.1 to 1.6
            • Mikes2
              • 1704
              pretty sure it was a 17mm on my car
              Mike
              http://www.s2-audi.co.uk
              • K Simmonds
                • Dec 2007
                • 7627
                Second that, I'm almost certain the F22 on S2's and RS2's are 17mm.
                1994 MTM RS2.
                2000 B5 TQS.
                • Bimmerod
                  • Nov 2019
                  • 29
                  Alright, parts should be here on Friday so I plan on tackling it this weekend. I will keep you posted on how things turn out.
                  Thanks again
                  • le mans
                    • Nov 2013
                    • 165
                    • Country: New Zealand
                    #39
                    That's interesting. What is the 'bigger oil filter'?
                    • Laaf
                      • Oct 2010
                      • 275
                      There is info on filters.
                      Are you guys running the larger revised Oil Filter - 068 115 561 B
                      Or the original - 06A 115 561 B
                      • Bimmerod
                        • Nov 2019
                        • 29
                        I didn't really get any change when switching to the larger one. It was only a 0.1-0.2 change but not sure if it was the oil change or the filter that had something to do with the increase?
                        It does fit in there fine but it is quite a bit larger than the stock filter. It took about 4.7-4.8L instead of the usual 4.5L to fill.
                        • Rikki Kitto
                          • Feb 2010
                          • 6276
                          Think it helps keep the oil a little cooler too, I'll check when I get home what part number is
                          • Rikki Kitto
                            • Feb 2010
                            • 6276
                            Try this one out I've been using them for a few years now seems happier with more oil
                            • Bimmerod
                              • Nov 2019
                              • 29
                              The MANN part number for what I used is W940/25 which is a little different than the picture above.
                              The one you posted might be a little longer but very similar.
                              • K Simmonds
                                • Dec 2007
                                • 7627
                                That’s interesting, the one Rikki has posted a pic of looks like the one for a T4 Transporter, in fact I’m almost certain it is, I still have one at home left over from my old work van, would have to check the part number to be sure though. If it’s the right one I’ll give it a whirl on my RS2 next time I drop the oil out, the extra surface area inside should in theory help keep the oil clean for longer and the extra exterior surface area aid cooling.
                                1994 MTM RS2.
                                2000 B5 TQS.
