cam belt position is looking odd
  • Tom_
    • Oct 2007
    • 1301
    • Country: Czech Republic
    #91
    Originally posted by S2_avant 19930325
    There is a brand called SWAG , that has the bolt . Do you know anything about the brand ?
    SWAG brand is ok..some parts they delivered as an OEM parts , but you will noticed that stock Audi marks are grinded, because they cant sell it as OEM ones, but they are..Febi as well, good brand.
    Audi Coupe Quattro 2.3 20V
      • Dec 2017
      • 5983
      Febi bolt next to OE
      • K Simmonds
        • Dec 2007
        • 7627
        Hmm, that Febi one looks more like the bolt for a 3B or 10V motor, I have some used ones in my workshop, will take a look in the morning.
        1990 B3 2.0 80 quattro.
        1992 C4 2.8 Avant quattro
        1994 MTM RS2.
        1998 B5 TDI quattro Sport.
        2000 B5 TQS.
          • Dec 2017
          • 5983
          It's a Febi 17230p and listed as oe fitment on S2
          • K Simmonds
            • Dec 2007
            • 7627
            Typical eBay advert, says it fit's this and that and doesn't, I find half the listings nowadays are like that.
            1994 MTM RS2.
            2000 B5 TQS.
            • S2_avant 19930325
              • Mar 2019
              • 648
              Got the lower cambelt sprocket .. behond the sprocket ,, there should themm washer be.. so first wasgher then sprocket.. correct ?
              • S2_avant 19930325
                • Mar 2019
                • 648
                If not ,,, what stops the sprocket to move it self towards the engine/crankshaft ?
                • S2_avant 19930325
                  • Mar 2019
                  • 648
                  Behind the sprocket there is nothing , , the only thing that makes it stop go in is the groove in the shaft. It should come about 4mm or so. The thick washer goes in front .There was nothing else when i disassembled it .. hmmmm .. getting tired .....
                    • Dec 2017
                    • 5983
                    The diamond washer fits in that slot on the pulley. Did you get a new one?
                    • S2_avant 19930325
                      • Mar 2019
                      • 648
                      Explain how you men ? Is there something behind the pulley i should put or no ?
                      • S2_avant 19930325
                        • Mar 2019
                        • 648
                        The diamond washer goes after i have put on the sprocket.
                        • S2_avant 19930325
                          • Mar 2019
                          • 648
                          Now i get it ,, when you put on the complete set of pulleys ,, then that will be what holds it .. and the washer must go under the bolt head .. correct ?
                            • Dec 2017
                            • 5983
                            Yes, diamond washer goes in slot on the outside of the bottom pulley after its on the crank. Fit the vibration damper over that and main bolt in the middle. Bump on the outside of pulley lines up with vibration damper. Refer to my earlier pic I sent you.
                            • S2_avant 19930325
                              • Mar 2019
                              • 648
                              Kit wrote .... (((Yep, behind the bottom cam belt pully there should be a thin washer which is diamond coated and stupidly expensive)))))
                              , it's been few years since I did a belt on an ABY/ADU and I honestly can't remember if there's a thick washer in front of the pulley or not. However my memory says no there isn't one and I can't find one on any of the diagrams I've just looked up, just an 18mm bolt with a shouldered head. Maybe Dave or someone else who's done the job on an ABY/ADU more recently can chime in here.
                              You wrote .... Only the diamond washer should be there as Kit says
                              So i understood as KIT wrote ,, it should be behind the bottom cam belt pullley.
                              But better to measure twice and do once.
                              Thats why im checking twice. But no i know ,, first the pulley vand then the diamond washer , the belt hub and then the damper.
                                • Dec 2017
                                • 5983
                                I think Kit meant behind the damper. The diamond washer fits in the recess in the bottom belt pulley which can only fit one way as it engages with the slot on the crankshaft. Put it all together and it's self evident.
