cam belt position is looking odd
  • John.
    • 2615
    Wondering if anyone has noticed this on fitting a Gates belt on the ABY, the teeth appear as if they're a fraction too small for the cam pulley?
    After I'd tensioned the belt I went to turn the crank anticlockwise just enough to make the slack go to the longest run between the cam pulley and water pump, so I could then give it the 90 degree twist check . I've taken a picture with a light shining behind the pulley so you can see what I'm on about!
    Anyone else noticed similar when doing their ABY belt?
    Belt is a 5269XS
