I have an issue here.After i replaced all vacuum hoses i wanted to do a boost leak test,with a kit i bought last year since i hadnt done one all this time.
i couldnt even manage to get air into the system.It kept coming out!!!
i connected the MAF plug with the valve,and also the small one you see in the picture.
the air was coming off the dump valve and N75valve area but i couldnt determine where excactly!i think i have to dismantle the front bumper to check the hoses below the intercooler....
but if i was loosing so much air so fast,how could i be having a good boost at 3500rpm holding 1.5bar as it should?Is it possbile?
also could all this air leaking be having anything to do with my rich mixture and my emmissions?
