wastegate spring!
  • Slim m
    • Jun 2006
    • 104
    wastegate spring!
    Can anyone tell me if there is any visual difference between the original wg spring and a stronger one??
    Liam.
    Welsh back lanes are the best!:mischeif:
  • merlin's S4
    • Jan 2005
    • 1539
    Yes! Put the two along side and you can tell straight away.
      The one on the right I believe is a stock S2 spring it has a total of 6 turns, the one on the left is a from a ur, the wire is thicker and it only has 5 turns, less turns = stronger and thicker wire = stronger.
