I fitted the 7A Exhaust cam to my car expecting to get a bit better breathing up the top end, I'd read that fitting both cams might lose me some low end so just went for the Ex cam.
What I think I'm noticing is that the car actually doesn't pull so well up the top in the high gears, boost is starting to drop off above 4k and the engine seems to go a bit flat above about 5k, I'm actually tempted to put the 3B Ex cam back in as I seem to remember that the car used to just keep on pulling past 5 in top, it used to just drive up to the top end of the speedo..(The old speedo though, the plasma speedo goes up to 180..) Obviously its difficult to test this without going to an autobahn..
Problem is I havent got any actual figures to compare, does anyone else have any experience of this?
The exhaust cam should be opening the exhaust valves open for slightly longer or further open allowing the better removal of gasses from the cylinders, also helping the turbo spool up quicker. Can't see how it would have an adverse effect, unless it was out by tooth on the chain?
