Alternator - what choice to make
  • S2_avant 19930325
    replied
    Aha in the front the small one ... if that is at fault .. you get a red flashing oil can on the dashboard ? Is there somekind of oem number on it ?
  • steve briance
    replied
    Temperature sender is screwed into the bottom of the oil pump.
  • S2_avant 19930325
    replied
    The temp sender isnt that the one with one pin ? Which three is there ... it thought there were only 2 sensors that monitors the oil.
  • S2_avant 19930325
    replied
    Both of the sensors ,, the big one with 2 pins and the on under it ,, with one pin are new. I know they are ok. Which one is the temp sender ??
  • K Simmonds
    replied
    Glad the Alternator sorted out your voltage problem...
    If you've changed both the pressure senders and put the wires back back to the correct connections which it sounds like you've done then that just leave's the temp sender to give a signal to set off the Autocheck.
    The larger of the two pressure senders supply's the signal for the gauge and the 0.3 bar at idle alarm, it's possible you have a duff sender or one with a different pressure switch, there are a couple of variants. It should say on it which type it is, normally in very faint script on the 17mm fixing.
    Check the wiring to all three senders.
  • S2_avant 19930325
    replied
    So i went with recommende alternator. I did maintence on it . It was used. Now i have 14.5 volts in charging and no battery lamp flashing. So there is one problem left.
    The oil lamp flashing on dash board. I have changed both the oil sensors/switches on the left side on the engine. The big bulky one and the small one. Hmmmm.
    Is it possible that i have bad oil pressure on the big one ,, the small one is to dashboard by the gear lever. It shows 5-6 bars when i start cold. And the big dashboard , the oil lamp starts directly.
  • Antsa
    replied
    Originally posted by S2_avant 19930325
    I bought a used 078903015A ,, is there a thread on refurbish them ,, i belive Antsa did something like that but cant find the thread
    Yes I have done it a couple of times, and I've been meaning to do a how-to on the subject but it seems like I can't get anything done these days The pictures could also be better but hopefully they make some sense.
  • B5NUT
    replied
    This has the process on the rebuild. https://www.s2forum.com/forum/member...e7#post2078101 It's very simple and a massive saving over buying a new alternator.
  • S2_avant 19930325
    replied
  • S2_avant 19930325
    replied
    Constant 38 amp when running ,, and intermittent load short time. If thats what intermittent means
  • Bowie69
    replied
    Only an intermittent load, of course.
  • S2_avant 19930325
    replied
    Originally posted by B5NUT
    Doesn't the radiator fan use a ridiculous amount of amps It certainly causes the engine revs to jump when it kicks in
    The fan wants about 38 amp , but it can jump up higher but just for very very short time .i have measured it
  • Bowie69
    replied
    Yep, does on the 7A as well.
    Heated rear window another big thing, plus potentially 6 headlamp bulbs all on at once.
    But still no where near 90A.
  • B5NUT
    replied
  • steve briance
    replied
    Its a little bit like having 500cubic cm per minute fuel pumping capacity when you only use 100.
    The 7A has a 90amp alternator, I've never felt like im short of charging ability. Just curious as to what extra electricity circuits does the ABY s2 have to need the extra 30amps?
