Good evening,
I have an issue and I would like to know if someone can help me to solve.
The case is that when the car is running and taking temperature, fan doesn´t work. Only when temperature gauge goes close to 105-110 degrees, second fan speed start working. But first speed never works.
But, when you switch off the engine, first speed fan start working automatically.
I had been looking the reles, fuses and the sensor but I don´t know where I can check the first speed. My car doesn´t have air-conditioning.
the radiator has this sensor ( 2 pins)
This is the rele box, but I dont see the a rele for first speed. All fuses are checked and in good condition.
N89l2ZDp98W7ycKtdll-NvLsuVS4wyETiSWEkTBt36EaTvU16bPBSEh0HrrdgHjh1SIZzwDNNrQlajDCvSp96MMY91cdbacIFYb1YXkeQhwKCHJ9IbvxJZv8JYdJF3GmUOYLHdEB_ElOM5eM599u-LxlVaIULP1Vmdz3VgD4hM_e1dn5kLUPOiupMhnPwGB83OUVDvFrty4KahehLAFn9d0iBG3GDYLmNPRmRSfuCIqMcqwQwURfWdmvHNzdRcp
does anyone know how to check first speed? I understand that It must run close to 90º, but I only take that temperature at the highway, when I go across the city, It increase to 110 and sometimes warning appears.
To add, Coolent water, termostat, temperature sensors are all new.
