Turbochargers for 500hp
  • larsaskogstad
    • May 2020
    • 674
    • Country: Norway
    So as I read the earlier post where discussed everything from Holsets to EFR's,
    By todays standard, what is the best 500hp+ turbo? ( on pump fuel )
    EFR?
    https://www.s2forum.com/forum/member...-3b-1991-coupe
  • vidar skotheim
    • Apr 2005
    • 566
    • Country: Norway
    K26/27
    • AndyP
      • 6049
      Originally posted by vidar skotheim
      K26/27
      You don't think things have moved on in the past 30 years then?
      • larsaskogstad
        • May 2020
        • 674
        • Country: Norway
        Garrett: Garrett G25-660 , Garrett G30-660 ,GTX3071r gen II , GTX3676R Gen II ?
        BorgWarner EFR ?
        Xona?
        Pulsar?
        Just wondered what people are running in their setups + dyno
        • vidar skotheim
          • Apr 2005
          • 566
          • Country: Norway
          Mine k26/27 have modern design wheels and new better design ex housing .
          and nice bolt on original look .
          • varia
            • 821
            • Current: United States
            EFR 7163 is a good one
            • rxl
              • 1913
              got a dyno run with that turbo?
              • vidar skotheim
                • Apr 2005
                • 566
                • Country: Norway
                Yes . This from a normal engine build .
                • K Simmonds
                  • Dec 2007
                  • 7627
                  Vidars Turbos are awesome bits of kit from the photo's I've seen...
                  It's surprising what can be crammed into old K26/7 housings, the Holsets are great but are not plug and play like a K26/7.. That share's the same center section layout as stock, so oil and water lines are a straight fit, as is the down-pipe, you may have to get a little inventive with the MAF boot depending on what compressor housing you use but that's really a very mnor issue.
                  I opened out a stock 3B MAF boot with an exhaust flaring tool and a heat gun to make it fit on larger intake's, I still have it knocking about if you end up needing one.
                  1990 B3 2.0 80 quattro.
                  1992 C4 2.8 Avant quattro
                  1994 MTM RS2.
                  1998 B5 TDI quattro Sport.
                  2000 B5 TQS.
