Anyone experience constant clicking when filling up the S2 . Tried different petrol stations and the same issue can barely fill it up as can’t get the fuel out the nozzle , it’s gone so bad that it’s easier to use a Jerry fuel can . what are the things to look into on the S2 ?
it doesn’t matter what I do to the fuel pump nozzle . If I leave it half way out of upside down it’s the same.
checked carbon canister and all the fuel lines seem good . Tested to make sure it’s not blocked .
we suspect it’s this bleeder valve ?
Part Number: 895201146B
Should this be one way only ?
anyone have any experience in this as I couldn’t find a post similar to this issue. Where fuel pump clicks before the tank is even full.
many thanks for any help.
