Hi all,
In my quest off tackling my Cabriolet's cooling issues, I've tried to replace the thermostat today. I can't however figure out how to access the 2 bolts holding in the thermostat shroud (number 1 & 16 in belows picture). Does anyone know how to access these bolts? The power steering pump & the left-side radiator trim are in the way. The Audi workshop manual just tells me to remove top radiator trim, which I did, and then screw out the two bolts holding the thermostat shroud. Any help would be greatly appreciated.
Luuk,
Luuk,
