Afternoon guys, I've been checking fluid levels etc as pat of routine maintenance and discovered the main fan and rad are not attached to anything other than pipework on the left side (next to the engine) and I can't see anywhere that it should be fixed?? Any info will be gratefully received.
There are only three fixings. Big one at bottom, smaller one on side by pas reservoir then a bar from the slam panel to top of rad. All should have rubber mounts.
Thank you so much for your input. I definitely don't have the parts 8 & 9 in the diagram ! Better get on the hunt for those parts unless someone has the brace 893 121 259b they wish to sell?
