Wobbly radiator!
  • Pibbow
    • Jul 2022
    • 70
    • Home: England Current: Scotland
    Wobbly radiator!
    Afternoon guys, I've been checking fluid levels etc as pat of routine maintenance and discovered the main fan and rad are not attached to anything other than pipework on the left side (next to the engine) and I can't see anywhere that it should be fixed?? Any info will be gratefully received.
    Cheers P
    • Dec 2017
    • 5992
    There are only three fixings. Big one at bottom, smaller one on side by pas reservoir then a bar from the slam panel to top of rad. All should have rubber mounts.
    • B5NUT
      • Sep 2021
      • 1071
      As Dave states there are 3 mount mounts. Look like you could be missing a few parts
      • Pibbow
        • Jul 2022
        • 70
        Hi guys
        Thank you so much for your input. I definitely don't have the parts 8 & 9 in the diagram ! Better get on the hunt for those parts unless someone has the brace 893 121 259b they wish to sell?
          • Dec 2017
          • 5992
          Sit down. They are expensive.
          I think I have a spare somewhere.
          • Pibbow
            • Jul 2022
            • 70
            Dave that would be amazing. I was just about to order one from Tradition....let me know if/ when you find one.
              • Dec 2017
              • 5992
              There is one in eBay for £20. I would snap that up. It needs Sand blasting but should clean up nicely. Seller is a member here.
              • Nuvo
                • Nov 2003
                • 3825
                Maybe this one is still available: https://www.s2forum.com/forum/member...diator-bracket
                • Pibbow
                  • Jul 2022
                  • 70
                  Got it Dave, thanks again mate..
