I’ve recently had a couple of niggles with my 3B which I have ironed out by replacing the ignition components. However she is running great but on occasions after a minute or two following cold start up does a little cough or two. It’s defo temp related and I think im right in saying the 3b uses the MFTS to send temp signals to the ECU as well as gauge and overheat boost cut..
Has anyone had a similar issue with their 3b and where is the best place to get a MFTS from now. I think mind is a BEHR or MAHLE and I replaced it shortly after getting the car…
my running issues started after not using the car at all for 18 months as I was too busy with life/work. As I took the car for the mot in June she just about scraped through emissions which I have never had an issue with before. Then on the way home developed a misfire at 3800 rpm then was running on 4.5 when I got home.. As I say there was corrosion on all 5 HT leads at both ends. New cap rotor arm leads and plugs resolved this..
