Urq 20v rr maf
  • predding
    • Aug 2009
    • 132
    Urq 20v rr maf
    I have 1990 model (never sure if it is ABY or AAN engine) and have now done tests on original MAF v Chinese one I bought that made no difference to stuttering under load
    Using the Test sheet from this forum, Ohms are correct but zero volts across Pins 3 and 5 which looking at the schematic wiring feed the hot wire circuitry
    The chinese MAF shows correct 2.5 to 3 volts reading across pins 3 and 5 but engine still wont pull
    It idles smooth on all cylinders but running rich from exhaust
    Many ppl have said it needs to be original OEM to work (also a mates garage guy on his Discovery which fixed the same problem immediately) BUT I cant find an OEM unit anywhere
    Does anyone know anyone who can test and maybe replace the hot wire in the MAF etc
    I printed out all the hard copies from the G70 Datasheet pages on S2 Central but it all seems to have disappeared now
    Hi Predding
    I should have a good spare MAF at home, I can send it to you to try, send me a PM.
    I will be back home on Tuesday.
    A 1990 RR engine would normally be like a 3B with single coil and distributor, ABY, ADU and AAN have the 5 coils on plugs and later Motronic ECU to suit. The same MAF will work for all.
