MFTS single wire replacement?
  • booested4door
    • Feb 2015
    • 120
    Hey all! Does anyone know what sender i need to replace the MFTS with in my b2? AAN doesnt use it and i only need the temp gauge to work on the dash. Believe its an M14x1.5
    thanks
    james
  • _ShurikeN
    • Mar 2010
    • 733
    • Country: Russian Federation
    VAG 049919501, 0499195011 if you find or make M10x1 thread for it somewhere.
    Worked well on my 10V, there is a factory thread on the cylinderhead.
    • booested4door
      • Feb 2015
      • 120
      thank you man! going with the original 4000 b2 sender for the use of coolant over temp light and ac cutoff. using an adaptor as you mentioned! appreciate it!
