MFTS single wire replacement?
  • MFTS single wire replacement?
    Hey all! Does anyone know what sender i need to replace the MFTS with in my b2? AAN doesnt use it and i only need the temp gauge to work on the dash. Believe its an M14x1.5
    thanks
    james
    VAG 049919501, 0499195011 if you find or make M10x1 thread for it somewhere.
    Worked well on my 10V, there is a factory thread on the cylinderhead.
      thank you man! going with the original 4000 b2 sender for the use of coolant over temp light and ac cutoff. using an adaptor as you mentioned! appreciate it!
