waking up my s6 from hibernation this weekend and i noted a coupla drops on the ground. after a bit of poking, it seems to be coming from the front of the engine. all hose connections are dry. i THINK that leaves the water pump as the only possible source. of course, it's only got 10,000kms on it as does the timing belt and pretty much everything else on the engine....
can't recall what brand it is but i guess it's trash??
probably easiest to replace it with the bumper/rad removed?? i am praying i don't need to remove the crank pulley? and most importantly, recommendations on not crap pumps? i mean, i COULD spend 160 euro on an oe one from tradition but i hope that's not going to be required??
thanks
thanks
I can't seem to find anymore information about this online.
