Hi everyone,
my cylinder one isn't firing, no matter what I do! But first the basics.
My setup (relevant parts):
- S2 3B
- compression reduction plate (8.2:1)
- EMU Black ECU
- Stock fueling system
- Stock ignition system
History of symptoms:
Last year I had this setup, without the compression reduction plate and everything worked. This winter I built the head, added the compression reduction plate and switched to single coils (R8). After starting the car, the first cylinder didn't work. I tried everything (list below), but changing back to distributor igniton to use the stock ecu made the engine run on all cylinders! So I am pretty sure, the fault has to be either the EMU (soft- or hardware), or the wiring adapter from the stock ecu plug to the EMU.
Troubleshooting:
1. Checked the map - everything looks fine. The car ran with this exact map last year.
2. Checked continuity between cyl1 injector and EMU pin-
3. Removed fuel rail and cranked engine. All injectors squirt out fuel equally.
4. Installed a new wire to the cyl1 injector on plugged it into the EMU pin for injector 6. Then I set injector 6 to replace the first one, to test if the EMU pin was faulty.
--> These tests make me believe, that the EMU, the wiring and function correctly
Troubleshooting before figuring out OEM ECU works (with sigle ignition)
1. Checked EMU settings
2. Spark plug ignites when car is running. I took it out and then startet the engine with 4 cylinders
3. Changed injectors, coils and spark plugs with other cylinders
4. Checked timing on cyl1 with a timing light
5. Removed fuel rail and cranked engine. All injectors squirt out fuel equally.
6. Switched connectors from injector 2 and coil 2 with the one from cyl1 and switched cyl1 and cyl2 in the EMU settings, to eliminate a wiring/connection fault
7. Checked compression. All good on all cylinders
8. Checked valve train visually. Removed valve cover and intake manifold to watch valves, cams, hydros move.
So all in all I have to idea, why it is working with the stock ECU, but not with the EMU. This makes me very sure, the issue is not mechanical, but a problem with the EMU or some wired close to the EMU. I checked all possibilities and can't think of anything else to test. I'm running ot of ideas of what to test, so please help me out, if you have any idea. Thanks!
- S2 3B
- EMU Black ECU
Troubleshooting:
