Hi,
Was hoping for some advice if possible! I have an ABY S2 Avant, and in the past few days it will cut out while driving. Car won't restart, but if I leave it for 5 - 10 minutes it would run for another very short period of time (minutes) before cutting out again.
It feels as though engine power is completely lost, you tap the throttle when you feel this happen and for a split second the revs climb but it will then cut out completely.
I had a local garage plug in their Bosch diagnostic and it came back with 1 error with the code 0231 (or 005561 0231 looking at the printout I was given). Searching online for this refers to 'Mixture adjustment control' - the bloke in the garage then pointed out if you append a P to P0231 it refers to 'Fuel pump secondary circuit low'. I'm not sure where that came from really unless he knows it's a thing with older cars being read with newer diagnostic tools.. Fuel pump woes make sense I guess?
Any thoughts or ideas??
Thanks in advance
Thanks in advance
