Does anyone know the part number for the coolant hose with the bleed screw in ( for 3b coupe,at the bulkhead to heater matrix) I'm guessing it's no longer available from Audi?, is there a replacement hose with the bleed screw in it? The bleed screw on my 3b coupe was leaking slightly so something had to be done, this resulted in the nut which the bleed screw goes into detaching from the hose, I've done a temporary fix with a largish bolt but I want to fix this properly.. If I have the oem part number I can cross ref if needed.. Has anyone found a single silicone hose to rectify the problem I now have? Or has anyone found a good sealer to seal a bolt soundly in the hole where the bleed screw was? Thanks in advance ..Al////.....
Part number for 3b coupe coolant hose bulkhead bleed screw one.
That looks like the one from my NG Coupe, with a short M8 bolt forced in to replace the snapped off the original plastic part, don't think it is the same one though. Samco have a bleed screw on theirs, just not sure it's available seperatly.
Don't think the OE part is avaiablle any longer.1989 B3 2.0 3A 80 quattro... Budget 1.8T Project.
Originally posted by Condor View Post
Hi Tractor Dave,just seen you put up a pic, is it for a 3b coupe yes??..it looks similar but difficult to see mine ..How much do you want for it? Cheers for now Al////.....Nothelle S2 Avant
Originally posted by Tractor Dave View Post
I can't remember what it came off. You cover post and it's yours.
:wave: :thumbs:
A big shout out to Paul of ROOSE MOTORSPORT who soon replied to my emails and I got the coolant hose with a bleed screw the next day after I’d bought it. Thanks to the others on this post too who took the time to give suggestions etc .. I’ve still got the bolt in the old hose atm, it’s a bit tight to get the new hose on at the bottom ?.I need to be in the mood to scrape my knuckles ?.. .:wave: :thumbs:
