Now checking the MFTS - see item 7 here https://audi.7zap.com/en/rdw/audi+qu.../919-101010/#9
I am also checking this as per sjm sheets - the 12v feed to the socket is OK but unsure about the sensor (it the original and the article says they are well know to fail http://www.sjmautotechnik.com/troubl...ing.html#gauge
I have ordered a new one. I also checked the Owners Manual as the digidash is showing 4 bars at high temp with ignition on
With the engine full of coolant ~15degC all 4 bars at high temp on the digidash were on so its not high temp but sending low coolant level signal. I also reads the same with the sensor connector removed so could this be a failed sensor. I havent checked the sensor on the back of the head item 9 in the above diagram (not sure what readings to take)
The Owners Manual pic is also attached which explains the segments - I have 4 bars at high temp with or without coolant and with the sensor plugged or unplugged - ignition on
