violent jerking and power loss
  • Olimat
    • Mar 2025
    • 33
    • Country: Italy
    Hello guys im new to the forum, and i don't speak english very well...
    I bought an audi s2 a few weeks ago, and it has one major problem above a variety of others:
    the car violently jerks under load when driving under hard accelerations, i've noticed sometimes it doesn't jerks and it pulls great but its rare, i tried cleaning the maf connector but nothing changed, and i tried to drive with it unplugged and it was even worse, the car has no problems while in neutral and revs freely, when it jerks it feels like it shuts itself down but it doesn't, and then it gives a big kick of power for a brief moment.
    im sorry for my english and thanks.
    By the way its a 1991 3b s2.
  • andyg plym
    • Nov 2006
    • 4646
    Have you done a boost leak test?
    • simons2
      • Mar 2010
      • 344
      Does sound like a boost leak
      • 5cylinderman
        • Oct 2011
        • 367
        You most probably have a boost leak. When the ECU detects a difference between requested boost and actual boost it will cut all boost for engine protection and cut all power, which from personal experience is quite an "Oh ****" experience.
        My issue was with the O ring on the left hand (port) side of the intercooler which had broken up.
        I replaced the O ring with a silicone reducer hose and all was well. This modification has been featured before on this Forum. I can't reference as I'm out and using my phone right now but this modification has been detailed before.
        Best of luck!
        • Ian Simmonds
          • Jun 2005
          • 2858
          ISTR this known as the Mark H mod.
          93 MTMS2 Avant
          • Olimat
            • Mar 2025
            • 33
            • Country: Italy
            thank you guys for responding, the dealer that sold me the car said he had done a boost leak test but it could be a lie, i forgot to say the abs light lights up when shaking, i will proceed to do a boost leak test as soon as possible.
            • Rikki Kitto
              • Feb 2010
              • 6276
              If it feels like the car is trying to chuck you through the windscreen it's a boost leak
              • Olimat
                • Mar 2025
                • 33
                • Country: Italy
                yes it feels like it?
                • Olimat
                  • Mar 2025
                  • 33
                  • Country: Italy
                  it does feel like it?
                  • Olimat
                    • Mar 2025
                    • 33
                    • Country: Italy
                    i mean it does, i dont know why there is a question mark
                      It's a glitch.. On Tapatalk the forum software replaces unknown emojis with a question mark.
                      • psiconauta911
                        • Oct 2007
                        • 613
                        • Country: Portugal
                        Mine did that a few years ago and it wasn´t a boost leak, and cleaning the maf connector didn´t solve it nor replaicing the maf conectors, the cables that went into the MAF conector were broken and had to be changed, solved it and never hapened again.
                        • Olimat
                          • Mar 2025
                          • 33
                          • Country: Italy
                          i tried to unplug the maf, but its worse, you had the abs light when the car was jerking ?
                          thank you
                            • Dec 2017
                            • 5987
                            A few things can cause boost cut. With my car it was a faulty fuel pump. Do a boost leak check first though as that is the most common cause.
                            • Olimat
                              • Mar 2025
                              • 33
                              • Country: Italy
                              ok i will try, thank you
