the power loss occurs in high rpm range
violent jerking and power loss
Run a boost leak test again. If thats ok, check the maf pins. Also check your fuel pump is good.Nothelle S2 Avant
Urs6 plus project goneComment
And the fuel filter. Any poor fuel delivery will cause boost cut as the mixture goes too weak.Nothelle S2 Avant
YesNothelle S2 Avant
My money is still on a boost leak - you need to do a proper pressure check (visual inspection of hoses is not enough)...
disconnect and connect the MAF a few times in rapid succession and remove the "moteur" fuses from the fusebox for a couple of minutes...Honda CBR 1100XX Blackbird Turbo....undergoing major changes.....
'03 ZX12-R daily hack.... lots of nice bolt ons...Comment
They can leak around the injectors, from the exhaust manifold gasket as well as the multitude of hoses... as I said, visual check is no good - replaced or not, might still leak.
What hose clamps did you use? For example, mikalor type are known to cause leaks as they don't do the job properly...Honda CBR 1100XX Blackbird Turbo....undergoing major changes.....
Do the ANN throttle body upgrade from the S4 S6You should be able to find a silicone replacement.
It's worth replacing all the hoses that see boost pressure including all the original cotton braided rubber vacuum hoses.
The only one I like to keep OEM is the throttle body hose, the silicone ones don’t fit so well and tend to pop off.
Your symptoms sound similar to mine and based on the errors im getting with my maxx ecu, it could be related to your trigger and or cam sensor signals.Comment
