Head and block work recommendations
  • Dobby84
    • Feb 2011
    • 1169
    Hello,
    Can anyone recommend somewhere in the Bedfordshire/Buckinghamshire area that can do the following?
    Pressure test head
    Skim Head
    Maybe some head work
    Deck Block
    Maybe hone
    Crank balancing
    I am about to strip my engine down to replace the bottom end bearings so not sure what work is required yet
    Basset Down definitely for the balancing.
    Give them a call, maybe they can do the other work or recommend someone
      Double post
      • Dobby84
        • Feb 2011
        • 1169
        Okay I'll give them a shout. Cheers
        • Crasher
          • Nov 2018
          • 139
          I used Vibration Free in Bicester to balance the custom made billet 2.5 92.8mm stroke crank for a customers Coupe Quattro project. Balancing an offset journal crank must be done using bob weights that have been set up to precisely weigh the same as the full piston assembly on each journal and it isn’t a cheap process. It is the same procedure as for an offset journal crank in a V8.
