Hello everyone,
I recently picked up a 313k mile UrS6 Avant that was non-running for the last 8 months to a year. I've been doing my best to bring back several of the broken things inside the vehicle.
One thing that I've been struggling with is the coolant temperature sensor / gauge on the cluster. So I'm going to walk through what I've tried, what weird behaviors I'm having, and say what I think is going on in hopes that someone can validate or give me a direction to move into.
So first; let me explain what I understand.
MFTS sensor is the one that communicates with the gauge cluster.
Grounding the pin (Pin "T", which is a brown/yellow wire below the unpopulated pin on the 3 pin MFTS), should cause the gauge to climb to maximum.
If the gauge doesn't climb to maximum the problem is in the wiring or the cluster.
What I've tried:
-Pulled off the connector from the sensor
-Found corrosion
-Cleaned corrosion
-applied electric grease to pins
-tested grounding the pin, had no success for the gauge pinning itself to hot, but had the needle rise from "nothing" to the first starting dot.
-removed and disassembled cluster
-reflowed solder joints on all connectors across the cluster
-reinstalled in vehicle
-tested grounding sensor again, had intermittent results, had some occasions where the needle would rise to the "starting point" but go no further, had some occasions where the needle moved UP to the point where I said "yep it's working", like halfway up the gauge. But couldn't replicate.
-thought that maybe I was having an issue with the contacts not contacting the wire I was using, tried different wires, tried removing the pin from the plastic connector and cleaning the heck out of it. No positive or consistent results.
-I checked continuity / resistance between the pin at the connector and the pin at the connector at the cluster (pin 3 & 16, both had good continuity, less than an ohm or two)
-removed the cluster again, tried specifically reflowing pins 3 and 16 (I know 16 is the right pin but I figured what the heck) and made sure to introduce some additional solder and ensured that I didn't short anything.
-reinstalled the cluster
-tested again this evening.
-in this test, I got positive needle movement, the needle was climbing and I was standing there watching it, all of a sudden the needle starts falling, and falls down below the "starting" point and basically doesn't move again for the rest of my troubleshooting.
-I have a video of this test, nothing is moving. Not the harness, not the car, engine is off, cluster isn't being shaken or touched. Nothing is moving.
So what do I think based on this?
1) I think the harness connection between the MFTS is OK
2) I think there is no intermittent connectivity in the harness
3) I think it's possible the MFTS is failed, but that's not contributing to my problem
4) I don't think any of the solder joints are broken between the cluster and the gauge. Nothing I could see anyways from an uneducated look of how the signal might flow across the board.
5) I think that the power to the gauge might be going out or the gauge itself might be dying.
6) I have not tested trying to ground the pin on the back of the connector to the cluster while the cluster is plugged in, but I have anxiety about possibly breaking the connector or something trying this and I think based on my evidence that isn't my issue.
Here are my questions:
1)
Can someone confirm if the needle has a "starting point" when the gauge receives power and enters "normal operation"? What I mean by this is, experimentally it looks like there's a "I have no power" state for the needle, and there's a "I have power but the temperature is too low to raise the needle" state. I want to confirm if this is a real state or not.
2)
Has anyone experienced a failure where the gauge itself is malfunctioning? If so, can you share your troubleshooting steps for that? Or point to the article that undoubtedly exists somewhere in the internet?
3)
Assuming my gauge is actually the culprit, is there a part number that I can hunt for for a new gauge? I really really need to have a functional coolant temperature gauge in the car and I am thinking that finding an operable cluster to buy isn't going to be cheap and is going to be hard to find.
I've been trying hard to use the multitude of resources that are out there for these wonderful wagons but I feel like I've hit a wall. So I apologize if there's a forum post somewhere covering this exact issue. It's really killing my vibe not to be able to roll around in it. (The radiator mounted sensor that turns on the fans is also failed, and I've been waiting until I could diagnose this issue to not have to order parts multiple times and pay shipping multiple times).
Thanks so much for any and all input.
What I've tried:
-Found corrosion
-Cleaned corrosion
1)
2)
3)
